Fuel Pump fuse box WARNING
oscar1
Member Posts: 804 ✭✭✭
Starboard motor quick working at the dock for not reason. During troubleshooting I find out the fuel pump was bad, because I was not hearing the initial low pressure pump noise when you turn the key to the on position prior to start the engine, plus I was getting power to the pump electrical connector but not fuel pressure. So i replace the low and high pressure pump inside the fuel Gen3 module, the fuel regulator and i also installed a new fuel relay to be safe, But my engine cont not working, so to my surprise one of fuse box in the engine harness was burned. The fuse still working but the plug was damages. Bottom line check your engine harness fuse boxes (remove the cap for inspection) for any loose fuses before it can do a catastrophic fire inside your engine compartment. following is the part Number for low and hight fuel pump plus a complete Gen3 fuel module and the Mercruiser fuse box repair kit, so you don't have to replaces the complete engine harness.
