Gaskets and screens for standard oval portholes
echandler1971echandler1971 Member Posts: 244 ✭✭✭
My rubber gakets are starting to fail. It looks like these may be the original 2005 gaskets. I'm looking to rescreen my windows, especially bedroom, with "blackout" screens that work like curtains, but I need to replace the rubber gaskets and also get the plastic ones that apparently surround the existing screens. This is an 05 360 FV. I'm not sure if they use the same windows across the whole line of boats in '05 or not.
Also, what do you do to tighten down the windows so they don't slam shut. Currently I'm using "load bearing" plastic forks :smile: .
Dan of Steel
'05 Rinker 360 Fiesta Vee
  • YYZRCYYZRC Member Posts: 5,540 ✭✭✭✭✭
    Do you have the Jim Black port lights?
  • echandler1971echandler1971 Member Posts: 244 ✭✭✭
    I wish I knew. I don’t see any label on them.
    Dan of Steel
  • SpyderwebSpyderweb Member Posts: 960 ✭✭✭
    Regarding slamming shut:  on mine, at either end of hinge, a small plastic cap pries off to expose a screw.  Tightening those screws stiffen the hinge to hold window open.
