Weathering a large oil spill in the bilge
echandler1971
Member Posts: 249 ✭✭✭
So, one of my 5.7 VP oil filter loop hoses started leaking and when under pressure, it dumped close to a gallon of oil into the bilge before I caught it (engine is ok). Hoses are replaced.
To clean, I:
1. Dropped 2 boom absorbing socks into the middle and poked them with a stick constantly.
2. Disabled the bilge pump
3. Dumped half gallon of oil-dissolving bilge cleaner
4. Next day, used a sacrificial el-cheapo shop vac to suck out the bulk of it, filling a 5 gallon bucket with the mess and funneling it into gallon jugs. I had a fire extinguisher at the ready just in case.
5. Disposed of socks in double trash bags (probably not the right thing to do, but …..)
6. Repeat of hose water and a cup of bilge cleaner followed by shop vac. 5x
7. wipe bilge with 3M pad best I could
8. repeat step 6 2x
9. Re-enabled bilge pump and dumped a ton of water in.
8. repeat step 6 2x
Although there was a bit of an oil sheen in the water, it wasn’t too bad and dissipated quickly due to the oil dissolver.
18 Oil/water jugs went to county hazmat drop off for disposal.
Dan of Steel
'05 Rinker 360 Fiesta Vee
I had an oil sensor go bad last season, leaked oil - but not a gallon.
In the fall, as a final clean - just before haul out pour a couple 5 gal buckets of warm water & a bunch of Dawn soap. Let it sit. Then drain plug it out.
