Cold Start Extra Beep
YYZRCYYZRC Member Posts: 5,586 ✭✭✭✭✭
Merc 6.2s with BIII drives
My startup sequence is as follows:
Blower
Both keys on (beep tone for each), wait for electronics to boot up
Start port engine
Start starboard engine
When I start port, I get an extra beep while cranking. Doesn’t happen on starboard. Doesn’t happen when the engines are warm.
Can’t find anything in the beep manual.
Ideas?
    Maybe it's a voltage dropout from a weak battery or bad connection.  Can you watch the battery voltages while starting?  See if the port voltage dips lower than the starboard.
    Same routine. My engines do the same. 2nd engine doesn't beep. This occurs even if you start them in the opposite order. For me I noticed it when I connected everything up to the smartcraft gateway.
    Thanks @davidbrooks !
    On my 342 there was a period of the same. Started doing it but no explanation and later that summer it went away and never came back.
    I just tried it starboard first and starboard didn’t have the extra beep but port did. Will keep messing around.
    Battery. Had similar before batteries crapped out.
    Will swap port and starboard batteries and see if that does it. Thanks @ian
    Also check the key switch connectors. I had one that was not “loose” but not tight either, slid off without really pulling sp that may have been a contributor.
    I had no beep on second engine when mechanic re-connected power plug that needed to be disconnected for vessel view mobile
    Swapped the batteries and now no extra beep on either side. Thanks @ian !
    Very interesting! Great tip!
