Starboard Engine Overheating Coming Off Plane
aero3113
Member Posts: 10,085 ✭✭✭✭✭
Last week coming back to the dock I pulled back the throttle levers to idle into our marina and the starboard engine overheated and the alarm sounded. I quickly put it into reverse then idle and shut down. I waited a few seconds restarted it and the temperature went down to normal like nothing happened. I figured it was seaweed or a plastic bag and it came off when I went into reverse.
Today we left to go to our destination, about a 40 minute run. All was good the whole way and temps were fine. Go to power down to get into the marina and it happens again, starboard engine overheated. I did the same procedure and started back up, all was normal again. What do you guys think is going on?
You could also swap thermostats between engines to see if a 15 dollar sticky thermostat is causing an intermittent issue.
Stuck open might make it run too cool in raw water. Stuck closed would impede water flow to the likely two small holes on the outside ring of the thermostat.
Many times when it sticks open you'll fail to reach normal running temps unless under heavy load (like a boat). Modern vehicles will throw a CEL it the engine isn't reaching proper running temp.
I'm not saying I understand it. It's just an observation: every time mine did what yours is doing, I'd change the impeller, and the problem would go away. It never happened on an impeller less than a season old.
There are small holes on either side of the thermostat to allow some bypass circulation. With no load and at idle one could, in theory, run with a stuck thermostat indefinitely so long as you kept it at idle.
@LaRea may be onto something about keeping fresh impellers as it would likely flow more water than an impeller that has begun to lose efficiency as it ages.
You're getting plenty of flow at high rpms but after you let off the engine is still extremely hot and while you are pumping water it's not enough flow to keep that cast iron cool.
As long as they aren't dried out or crack when pulling on the fins.
