Need a brass threaded elbow, 22 mm thread
LaRea
Member, Moderator Posts: 8,078 mod
Help! After a solid 4 hours of research, I'm coming up empty-handed. Where can I find a brass elbow fitting with metric M22-1.5 threads?
I'm adding a Reverso oil change system (5 ports for the engines, transmissions and genny). On my ZF 325 transmissions, the drain plug is right behind the flange for the drive shaft, and there's only 1.2" of clearance between the drain plug and the flange bolts. I need to replace the drain plug with an elbow fitting so I can connect an oil drain hose. Can't find one anywhere!
I'd prefer a street elbow (male to female) but I'd settle for anything at this point.
Crap just saw you said brass, that one won't work
PDP00319 is a female to male 22x1.5. Not sure if it's brass, it is gold colored but it's not listed
