Engine temperature heating up on my 342
John41
Member Posts: 120 ✭✭
So I finally had my mechanic out on the boat to see why my starboard engine was heating up. It looks like it’s time for new manifold and risers. They also mentioned sending my heat exchanger in to have it cleaned out. I have the Volvo Penta 5.7 engine. Should I use Volvo parts or can I go with something cheaper? Where can I get the best deal 💰
Barr is sold by Michigan motors which probably wouldn't sell something they wouldn't use on one of their high priced replacement drop in motors. Michigan motors or motorz isn't the only dealer so you can shop around for best price.
No matter which set you use I'd still put a straight edge on all mating surfaces before install. Even OEM can be slightly off. Your mechanic will torque these to spec but it's usually up to you to recheck the torque after a few heat cycles unless he's going to come back out to the boat and do it for you.
If you're in salt water you'll be doing this every 5 years anyway so I'd invest in a torque wrench. Replacing the manifolds is simple so long as you have some 3/8 all thread to keep the gaskets in place while you install the manifolds.
I'd also add exhaust bellows to the to buy list if they're swollen at all. If installing new hose clamps recheck those after a few heat cycles as well, they stretch.
