‘05 342 lower door track
Anyone know where to source a lower door track for an ‘05 342?  Ours has a long crack and needs to be replaced.  I have the door off and just need to find a new one. Thanks.
  • aero3113aero3113 Member Posts: 9,969 ✭✭✭✭✭
    @Raven it’s possible Great Lakes Skipper might have it https://www.greatlakesskipper.com/
    You’re able to get the door out without having to remove the map case section to the left? I have to replace a screw on one of my tracks and was wondering.
  • RavenRaven Member Posts: 4 ✭
    yes,  door came out easy without removing the cover to the left.   4 bolts on the lower track and 4 screws on the upper.
  • YYZRCYYZRC Member Posts: 5,501 ✭✭✭✭✭
    Try BoatOutfitters.com. I bought parts for my cabin door from them.
    Would a plastic rectangle tube work and then cut out the top like the one is currently cut?
    Or an aluminum rectangle tube and then paint it white or have it powder coated.
    I think I'm looking at the correct piece in the photo.
