Outdrive Paint Recommendations?
YYZRC
Member Posts: 5,586 ✭✭✭✭✭
I painted my Bravo III drives last winter with the Merc primer, Merc phantom black paint and Merc clear coat. They looked brand new.
Now, they look like they are 20 years old after 5 months in fresh water. Can anyone recommend a quality paint?
I'm assuming the merc prime is intended specifically for the aluminum drive but on anything aluminum, stainless or plastic I like to add adhesive promoter to the surface before I prime. Seems to leave a better lasting finish.
Also avoid steel wire when prepping aluminum or stainless.
A good wash with purple power or even dawn dish soap, warm water and good scrub brush should be sufficient.
Then after sanding the engine drive well with im assuming 220 is recommend for that you need to clean as second time. Repeat the good warm water wash and then go back and clean with a mix of 50/50 water and isopropyl alcohol. Walmart is the cheapest, from the pharmacy section. Clean and wipe off with white lint free towels until you no longer see any dirt coming up.
Now you're ready to start applying.
There is a flash time likely between the prime and paint. If you'd wait too long and it dries you'll need to sand, clean and then paint.
Sadly, if the surface isnt prepped well just the force of the water under operation will peel the paint off quickly leaving the exposed non painted surface to quick corrosion. The coatings that hold the best do so with both a chemical and mechanical bond. Make sure whatever paint/primer you go with is compatible and follow instructions as closely as possible. Simple thing things like air temp and humidity can have a large effect on the durability of the finish.
You'll see cars with paint peeling off the front bumpers all the time where a cheap body shop or used car lot just sprayed a cheap Chinese replacement bumper with zero preparation or lack of proper prep put into the paint job.
After a bunch of research, I'm going to try this epoxy based paint: https://www.protekpaint.com/product/2k-epoxy-reusable-spray-paint/
If it fails to impress, I'll switch to Trilux 33 antifouling paint and move on.
I fight the shop owner with this as he thinks rainy days when the shop is slow would be the best time to paint his projects. Which it would be if we had a temp and humidity controlled paint booth instead of a 1930s gas station cinder block building.
I guess it could also be fish eye which is caused by some sort of grease, oil, wax or other contamination being on the painted surface.
