Trim motor problem
pearson57842pearson57842 Member Posts: 31 ✭✭
I have an issue with my starboard trim motor.  When I press the switch on the digital throttle control it just gives a continuous clicking noise.  I used a jumper wire direct to the motor leads and the motor is working fine as the drive goes up and down with the jumper wire.  I replaced both solenoids and that didn’t solve the problem.  Looking for suggestions on next steps to solve the problem.
    New solenoids, known good hydraulics and battery ... the only thing left is the switch at the throttle.  Put a volt meter on the solenoid terminals and have somebody operate the switch to see what happens?
  • aero3113aero3113 Member Posts: 9,946 ✭✭✭✭✭
    Check all of your grounds as well.
  • rasburyrasbury Member Posts: 8,989 ✭✭✭✭✭
    I had a bad switch in my handle...easy fix.
