Genny not running correctly
raybo3
Administrator Posts: 5,623 admin
OK I need some help with my genny. It's a 2002 Kohler 5E. It starts OK and runs for a few minutes just fine. I put a load on it and it will run for a few minutes then it starts to "hunt" and runs at lower rpm's than it should, then runs OK and it will "hunt" again then shut down. Starts right up and runs OK and starts........ well I guess you get the picture. It has new plugs and new impellor. I'm thinking may a carb issue. Does anyone know what the carb part number is? Thanks for any reply's.
2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org raybo3@live.com
Can you pull the fuel hose to verify adequate fuel flow to the fuel pump and/or adequate fuel from the fuel pump to the carb.
