ProIsoCharge Isolators..........again
echandler1971
Member Posts: 249 ✭✭✭
'05 360 FV - ProIsoCharge 130a 2 alt in 4 banks out.
I know I'm beating a dead horse with these things and generally, these Promariner isolators are more trouble than helpful, but I'm at a loss for what's going on.
I have both engines out at the moment (new TAs getting installed). Both alternator cables (going to the isolator) are live with 12-14vdc.
1. Is this normal in that if a battery is hooked up, it will be live in the reverse when the engine is off (no diode stopping it)?
2. I thought the battery switch handled breaking the battery connection to this thing?
Thanks
Thanks
Dan of Steel
'05 Rinker 360 Fiesta Vee
On a side note, if the wire from the alternator to the isolator is longer than 40 inches, it should be protected by a fuse or breaker that would have popped when the circuit got grounded.
From the horse’s mouth
Yes, this is normal behavior. The prosio automatically latches to the engine start battery when it powers down so the alternator sees a voltage and will output when the engine is started. We strongly recommend disconnecting the batteries at the battery terminals before performing maintenance on your vessel. This behavior is normal and does not damage the alternator and allows the alternator to work properly.
Kind regards,
Zachariah | Technical Support Representative | NAVICO GROUP | POWER SYSTEMS
