Gear lube leak
RetselRetsel Member Posts: 4 ✭
2003 fiesta vee 312
port engine gear lube leak
repaired small leak in connection
refilled still leaks but slowly
Should I just top off and monitor until boat can be pulled out of water ?
    Is it definitely a leak or could the level be stabilizing from replacing the gear oil over winter? If so, it will stop lowering at some point.
  • JoeStangJoeStang Member Posts: 1,144 ✭✭✭✭
    My lube monitor bottle was leaking slowly from the fitting on the bottom of the bottle, $60 for a new one fixed the issue.
    2013 276 Cuddy ~ 350 MAG / B3
    edited June 2024
    A pressure test, 5psi, should give you can idea where the leak is, if there's one .  Should hold 24+ hours.
    Do you ever notice any form of oil slick in the water by the out drive?
