Loss of confidence backing my 360 into the slip
echandler1971
Member Posts: 249 ✭✭✭
I’ve had several “scary” situations recently, where scary really means that I almost bumped into another boat in my marina (not exactly death-defying). Anyways, the issue is that I am in a tidal creek, I have isinglass over my cockpit (acts as a sail), and there are 2 goalpost pilings marking my slip that feel like they are 2” wider than my boat. Furthermore, my next door neighbors boat bayside of me sticks out past that piling into the channel so if I’m drifting outward in the creek, my swim platform could meet his stern if I overshoot on an outgoing tide.
When I’ve had to redo the run several times due to over or undershooting, I start to panic and lose confidence, but I end up getting the job done. I have twin VP duoprop SX-M and an underpowered bow thruster.
I tend to use just one of the engines and steer towards the direction I want the stern to move in reverse (kicking the boat in the direction I need it). I try to start pretty far out so I can sort of align with the goalposts, but the current sometimes is strong and I end up getting dangerously close to hitting the fishing boat next to me.
Since I have the duoprops, I don’t think the method of leaving the wheel straight and driving the boat with just the throttles like a Bobcat will work well.
What advice do you have? I haven’t really found a YouTube video for my specific situation of twin duo prop I/O drives in a tidal creek.
Dan of Steel
'05 Rinker 360 Fiesta Vee
The biggest change for me was previously I always tried to use the bow thruster as little as possible (maybe I was embarrassed?) but now I am not shy about it.
https://youtu.be/F2TNpfvn6QA?si=NakSU72JuhN6pDjL
I always used steering when docking with counter-rotating props. Still can't understand why people would discard such a useful tool.
Ray
2006 390
Previous 2000 340
Stern drives operate differently than twin screw inboards. I had a Silverton 34 Convertible (without a bow thruster) and those inboards could spin the boat on dime (because of the location of the props). Stern drive props are located on the back of the boat and while they will spin the boat just by adjusting the throttles, it is not as easy as having twin screw inboards.
With my (former) 350 EC, if it wasn't windy and there wasn't much current, I never used the wheel, just centered the steering and used the throttles and bow thruster. It is very important to have the wheel centered so the engines are straight. I had a steering angle sensor installed on my vessel view so I knew when it was centered - this is very important with stern drives.
Now when it was windy or the current was moving pretty good, I used both methods (that is just using the throttles, and also using the steering wheel when needed) - because I just couldn't get the boat to spin the way I needed it to in tough conditions.
To LeRea's point - if you have the tool at your disposal, you should use it when it is needed. When docking a single engine stern drive, your steer it into the slip because it iw the only way to get it there. Again though - this takes some practice and getting used to so you don't panic. And when steering, you always want to make sure to go back to center when going back to using the throttles only.
You can do so really cool things when using steering AND throttles at the same time. You can actually walk your boat sideway by turning the wheel all the way to one side and putting one engine in forward and one in reverse. You just have to spend some time getting used to it so it becomes second nature after a while.
You will mess us from time to time. You just have to be going slow. Neutral is your friend! If you are going slow, there isn't much damage that you will do to another boat by bumping it with just the current taking you into it.
Here are a couple of videos that explain how to move a twin stern drive boat sideways:
Greenwich Bay, Rhode Island
Also, getting that bow thruster and adding a stern thruster will pretty much put it on cheat mode
(for example, if you are backing and need stern to go to stbd, turn wheel full CW & bump in reverse a few times, in & out. While doing that, you know that your bow will want to move to port, so bump thruster to keep it from moving port. If you are close to your slip and need to move a bit forward and still to stbd, Turn wheel CCW & do the same, but bumping in fwd, knowing your bow will want to move again to the port. If you wanted to walk the boat completely sideways to the stbd, you would rotate between both of these two movements quickly and the boat would not move forward or reverse, just sideways. It is really fun to try and get good at. I have to do this a lot when going into fuel docks.)
