Cruisair reverse-cycle heat throws "LO / SE" error
LaRea
Member, Moderator Posts: 8,082 mod
Wondering if anybody has seen this fault in a Cruisair air conditioner. Reverse-cycle heat runs fine for five minutes, then shuts down with a "LO / SE" error -- which means the seawater temperature is too low. Sure enough, when I press the FAN and UP buttons to display the seawater temperature, it shows up as 22 degrees.
The thing is -- this system doesn't have a seawater temperature sensor. The circuit board has a blue plug for attaching a sensor, but there's nothing plugged into it. Somehow, the system thinks it has a sensor.
To "fix" it, I used a wire jumper to short the plug. Now it's heating fine on this 50-degree Michigan day.
I'm guessing the circuit board is starting to fail. Open to other suggestions.
