Air Conditioning Temperature/Humidity sensor
aero3113
Member Posts: 10,085 ✭✭✭✭✭
I was cleaning my basement and came across this sensor extension for the air conditioner. Did anyone relocate their sensor? Right now mine is located at the filter on the unit under the V birth. Is that the best place? Or should I use this extension and put it somewhere in the cabin?
I don't know why they don't just put it on the control panel ... and turn it into an ordinary thermostat??
I did have to move mine a bit ... it was far too cold close to the AC, and throwing the temperature measurement off. If you have the extension, I'd certainly try it.
"Ideally, the sensor should be located in a reliable return-air stream moving from the room to be controlled to the air conditioner it is plugged into. Locating the sensor on the back of the air conditioner coil is not ideal and can result in false readings for several reasons. It is best to locate the sensor just inside of a return-air grille or passage."
