Ouch, need help please
goalie59goalie59 Member Posts: 356 ✭✭✭
edited October 2024 in General Boating Discussions
I had a little battle with the crane well when pulling the boat the other day. I was and still am pi$$ed with myself. The outer port trim ring is what I am trying to find and have had no luck. Outside dimensions 18  5/8 by 7  3/4 . These are original windows on a 2005 410. Any help or suggestions would be greatly appreciated. Thanks
    edited October 2024
    @goalie59
    Pretty sure that is a Bomar Ellipitcal port window.
    Bomar 18″ x 8″ Stainless Steel Elliptical Opening Portlight Window
    I dented up the trim ring bad when a buffer got away from me couple years ago.
    I was able to disassemble it all & carefully pound out the stainless.
    Should be an easy replacement if you can find the part #
    If I remember right - when I removed the window there were quite a few part numbers on it for reference.
  • goalie59goalie59 Member Posts: 356 ✭✭✭
    Thanks for the info. It appears Bomar has discontinued this part. I am going to look into getting it repaired. I will update when I figure out if this can be done. Thanks again.
  • PickleRickPickleRick Member Posts: 4,390 ✭✭✭✭✭
    Have you checked great lakes skipper?
    Yes, that's the first place I checked but thanks for the suggestion.
    @goalie59
    West Marine & Ebay show some available......
  • Rich_Rich_ Member Posts: 361 ✭✭✭
    I have a hatch glass to replace- on the list- ebay seemed to have some options almost reasonable-
    Hope everyone is having a good winter. I just wanted to post an update on this and provide part numbers in case another member runs into the same issue. I finally found the part through Pompanette (Bomar). Members suggested I look there but after previous dealings with this company I didn't bother even looking into them. Going back several years ago with then trying to get a hatch and after spending several months of non callbacks ,emails not returned ect I decided to never deal with them. So I decided to try them again and to my surprise they have their **** together and have a great support crew. I had the proper trim ring in a couple of weeks. Part number is ST718-SS-1.375. I have previously bought a lot of parts out of the US and have had good luck, not sure how that's going to play out in the future with all the crap that's going on now. Hope this info might help someone in the future. Thanks for everyones help.
    I need to get back on finding replacement glass...
