Running new vhf wire
rasbury
Member Posts: 8,989 ✭✭✭✭✭
I'm about ready to unbolt the arch on our 270 to run the vhf wire...I'm way past trying to pull the new wire with the old one. I have a snake but can't it to make the up through the 1.5" hole or so under the sink area. I tried to cut the hole bigger with my tremol but it's really think there. The only thing I can see trying is removing the nuts on the inside and see if I can pull the arch away from the hull and create more space to make the turn? Crazy! Any other ideas? There are studs going through so is have to assume there is some flex to the arch as you would have to flex it to install it?
Also, not familiar with a 270 arch, but does it not have an access cover plate near the base? When I've run wires on the 310, I go up the arch from the base plate cover, and then down through the hole at the base to behind the fridge and then to the helm area.
The thing to remember is to also string an EXTRA wire/cable for the next cable pull and leave it there, and you won't have the same problem again...In my case, I wasn't using the TV cable at all, so it went bye-bye and will probably be replaced by Starlink one day.
I'm jealous of what the larger boats have like Tony's...maybe a small deck plate would be appropriate?
Thanks again-
After damaging my spotlight I called the local DMV to complain about low hanging trees. Took about 3 months but they came it out and cut the entire road. My boat sits about as high as your average 5th wheel.
