Odd run on the river
rasbury
Member Posts: 9,038 ✭✭✭✭✭
Hit the river today as it needed to be run and probably last chance before the holidays.. so it started fine- batteries a little low but started. Volt meter was showing like 10 volts but started coming up. As soon as I was able to accelerate it started coughing and spitting a bit...after a while it smoothed out but would not go above 3500 rpm. Sounded fine- was running smooth but just would not. Also have a noise- engine usually very quiet- this sound like an electric fan on a car- I'm guessing a water pump, alternator is in my future? When I lowered the hatch it changed the volume of it for a second...always something..
I'll have to spend more time with it and investigate further but it was such a drastic change from a run maybe a month ago..
when I turned on the water at the sink behind the helm- it seemed like super pressure and ran for some time-AND it was hot! How the heck could it be hot? It's a cold water only facuet?
As for the alternator, I would pull it and have it load tested at the local auto parts store and see if it makes any noise. If you have to replace it, but sure to use a marine grade alternator (spark protected.) I highly recommend DB Electrical on eBay. Great prices, no core charge.
The serpentine idler pulley is right next to the alternator and they can make noise too. While you're at it, changing out the tensioner pulley isn't a bad idea either if it's original. FYI those parts above are for Mercruiser. Please double check for parts compatibility for YOUR boat.
As for not getting on plane, you know your boat better than anyone, but I still have to ask: was it loaded up with burly fishermen (like me) and gear? Was the fresh water tank full, gas tank full, etc? With my stock 22" props I often could not get it up on plane when loaded...of course, move folks forward and eventually she would get up. Upgrading to the 4x4 props and pitching down made a huge difference for me.
When was the fuel filter last changed?
I have to use my trim tabs to get her up on plane and assume you have to also...have you verified they are working?
So, back to basics- need to get a fuel pressure gauge hooked up so I can see what is going on with fuel pressure, pull a fuel sample again. It's not missing and it is fresh fuel. I need to research if there is a guridian mode so if something is tripping that
Otherwise, within the last 20 hours have replaced all the filters, cap/rotor/plugs/wires. I did have bad fuel in it, pumped it all out and have run it several times since...also the cold water tab at the helm got hot again and then would hardly flow....but there was not a lot of water in the bilge when I did load it back up. Couple of weeks and I'll get back to it...
After you pull the old filters make sure you cut open the pleated filter and check the folds for debris/mud. If they've gotten dirty after pumping out the old fuel then I'd guess the tank wasn't completely cleaned of debris.
PM me your address and I'll send you a fuel cap gasket. My own post in a different thread motivated me to get a new one, but they don't sell singles...so a six pack it was. No way I'm going through 6 of them (in my dreams!)
I will equip myself with a fuel gage.
I will dump some heat- would like to find the electric pump I put together...see what is in there. It started and ran fine- will check the fuel cap - @Formulaben hooked me up with a cap gasket- there was not one on there. Thanks again!
What else can I check?
