Outdrive falling. No leak.
YYZRCYYZRC Member Posts: 5,605 ✭✭✭✭✭
My port drive won’t stay tilted up. There’s no leak in the system so I assume it’s a bad valve in the trim pump. Anyone know if this is serviceable or if the whole pump needs to be replaced?
  • aero3113aero3113 Member Posts: 10,106 ✭✭✭✭✭
    Maybe try to flush out the system and put in new fluid. Run it up and down a bunch of times as well, maybe it will clear out any debris holding up the valve.
    Do our pumps have a manual release like outboards do? Maybe it needs to be tightened if it does?
  • YYZRCYYZRC Member Posts: 5,605 ✭✭✭✭✭
    Some googling suggests that there might be an issue with the seal on the reservoir that is letting air bubbles in.
