Generator Ground
raybo3raybo3 Administrator Posts: 5,622 admin
Does anyone know where the generator gets it's earth ground from? I have a 342.
    edited May 2025
    On mine, the genny chassis was grounded to the port engine block and the port battery.
  • raybo3raybo3 Administrator Posts: 5,622 admin
    Wow I thought grounding the A/C with the D/C was a no no. Should never mix a potential cross voltage. Remember DC negative is really not a ground. So I find that very interesting.
    Oh, I meant the chassis ground (for the starter motor and engine) and you meant the AC neutral that the generator uses to provide AC power.  That goes direct to the switch at the AC breaker panel.  You are right, there's no connection from AC to the boat's DC ground buss.
  • FormulabenFormulaben Confirm Email, Member Posts: 233 ✭✭✭
