Vessel view
rasbury
Member Posts: 9,038 ✭✭✭✭✭
So, I sorta retired recently and lord now I hope for a little time for the boat. Keep in mind we have a disabled grand daughter, 2 great grandchildren 1st grade age and I'm 66.
I have inquired on here about mobile vessel view and I'm not sure I get exactly what benifit I will gain- I have a 2006 350 MPI. What I would be looking for is engine codes.
Can't believe it's been around two years since I pulled 75 gallons of bad fuel out of it. I replaced filters a couple of times, new fuel and it was running just fine- fast forward last time we were out around Easter it started fine but would not plane/exceed about 3500 RPM. So, before I pull 75 gallons of fuel out, again, would like to know if there is a code on the motor....high pressure fuel pump was replaced with the last fuel issue. And no, I did not put any stabilizer in it as was was surely going to burn that first tank quick! Not!
On the issue, have you pulled the water separator filters and drained into a glass jar to see if there is water again? I was having rough running issues and found that was the cause and kept running and clearing out.
