Front anchor locker drain
rasburyrasbury Member Posts: 9,016 ✭✭✭✭✭
I noticed my locker drain hole has a green goo coming out of it. Also, there are two other vent looking things on either side of the hull- one of those has the same goo. The rhode locker I understand must be full and needs cleaned out. I seldom have used it and must be rain water.   I will run out the line and see what I see- what about the other, what are they supposed to vent? Why would it be getting gooed up like that?
  • kordokordo Member Posts: 251 ✭✭
    Could be the recessed area where the windlass is mounted or the drain for the air conditioner pan?
  • rasburyrasbury Member Posts: 9,016 ✭✭✭✭✭
    I did get it opened up, don't know where the leaves came from but all clogged  up...but that lower small chrome vent on either side? I sprayed water down into the rhode locker thinking it would run thru- I had let put all the rhode but it was pretty clean...
  • IanIan Member Posts: 3,077 ✭✭✭✭✭
    edited November 2025
    On my 310 there is one either side for the windlass locker and 2 on the port for AC output and condensate drain pan. Anchor locker I think runs down inside to the after bilge pump under the bed.
