Winterize?
rasbury
Member Posts: 9,039 ✭✭✭✭✭
I don't think we have experienced the 23 degree weather we will see this weekend in ov 15 years. I don't know how long it will sit at those temps. I'm fresh water vooled so nothing in the motor...water system worries me a bit. Do I have concerns?
I use 4 gallons per engine also. But I have fresh water cooled and use the kit hooked up to the outdrive intake to suck it in. I then drain it all out of the block. I’m always worried it will freeze solid one day. I did a test once ( it’s on the forum somewhere), put the different antifreezes outside in a cup and waited for them to freeze.
If you ever wanted to start a landscape business in Florida, Wednesday next week would be a good day to do it- we will have landscapes gone over a lot of the state an iguana lizards falling out of trees in south Florida!
I run 6 gallons of pink through mine and call it good. A little easier in my setup as I only pull from the thru hull.
Like other said, run the water tank until empty, bypass the water heater and let it drain fully the. Blow the hot/cold lines until no water is left.
I always run pink through after I blow the lines out, then blow the pink out as well. I remove the screens to the galley sink as I think it causes corrosion if it sits for months over winter
If you have access to power, a shop light in the bilge and small heater in the cabin would be sufficient so long as you don't lose power.
Catch those iguana and bring them north to sell at flea markets lol
We had this 15 years ago- lots of stuff built in 15 years so we will see what the power company can do.
We also spent a week at the Dunedin marina which is close to caledisa island- which had pretty incredible docks there- don't recall if they had power/overnight docking- it's very shallow getting in there.
The intracoastal is very deceiving on depths. One year we were in the channel at low tide and we had sand visable on either side of us with birds on either side of us! Often passing is a bit of a clincher even in my bowrider.
Even pictures of them in peoples cars and homes.. it's astounding how many of these people are such low IQ..
I wish they'd vidoe when it wakes up.
