Tach is reading 5k at idle
ross5518ross5518 Member Posts: 3 ✭
When you start the boat, the starboard tach is reading 5k RPM's.  How do I fix this?
  • aero3113aero3113 Member Posts: 10,107 ✭✭✭✭✭
    Try tapping on the gauge with your finger. If that doesn’t work, remove the gauge and move the switch on the back a bunch of times. Make sure you put the switch on the correct setting when done. It’s a known issue and these tricks usually help, if not you’ll have to send it in for repair.
  • ross5518ross5518 Member Posts: 3 ✭
    Thank you! I will give it a whirl.  I appreciate the quick response.
  • grouch0jrgrouch0jr Member Posts: 287 ✭✭✭
    FYI, i just had my tach sent in to Faria for repair for a similar issue. It might be more cost effective to just replace the gauge instead of repair, depending on what you have
