Using Radar
JimGuy341JimGuy341 Member Posts: 108 ✭✭
For those with radar, do you run your generator when using the radar?  Or are the engine alternators enough to keep up with battery usage?  I have a Garmin Fantom 18" radome.
    I have only ever used my engine alternators to run all electronics
  • raybo3raybo3 Administrator Posts: 5,624 admin
    Same here just engines alt's
  • grouch0jrgrouch0jr Member Posts: 287 ✭✭✭
    edited April 5
    Specs for that radar show the max power consumption as 25 watts, which is a pretty small load. I've never turned my generator on for the radar.
    Your dual motors, isn't one of the alternator a dummy or not hooked up?
    @rasbury, No, both produce power and charge the batteries
    It’s the power steering pump on the port that is doing nothing typically.
    I knew it was something....two alternator must produce a lot of energy that is perhaps not harnessed? Not sure how all that works.
    Each alternator has a sense wire connected to the batteries. As the battery voltage increases (or decreases) the alternators will reduce (or increase) the charge voltage to maintain the batteries at approximately 14.2 VDC
