2014 290EX galley fridge issue
Went to start up my two crx1065 fridges in the boat the other day.  The cockpit fridge starts right up and shows a green light on the right inside the door.  The galley fridge does nothing, but the led light is on and the green light is lit.  It worked fine last year.  Figuring on checking the fuse and power connections at the rear of the fridge.  Went to remove the fridge..... There are 6 screws that seem to attach a "decorative" frame around the fridge.  Removed these and nothing budges.  Not sure if it is just stuck from gunk or what.  Don't want to start prying on something that isn't ready to come off/out.   BTW, I saw that just inside the fridge there are four plastic caps where mounting screws would normally go.  Pried those off and there are no screws..   If anyone has come across this, would be greatly appreciated.
  • YYZRCYYZRC Member Posts: 5,500 ✭✭✭✭✭
    edited May 26
    Does your fridge have the old style thermostat like this?
    Dometic  Waeco fridge thermostat CR80CR110 - fhpfi - appliance spare  parts
    If so, it's probably dead. Pretty common issue. Sometimes when they die the temp knob just spins freely.
  • paul7renopaul7reno Member Posts: 11 ✭
    It does indeed!   Temp knob does seem to have grip.  I'll look into.  Thanks YYZRC.
    Ordered one out of the UK.    I'll close the loop on this once installed.
    thx again
    finally got around to installing the replacement thermostat!   all good now!
    thx YYZRC!  closing this thread.
