Rusted elbow bolts
TickledPinkTickledPink Member Posts: 130 ✭✭
I'm replacing the exhaust manifolds, risers, elbows etc. on my 5.0L MPI and am stuck before I start. The elbow bolts on the top are all rusted shut and only one will turn.
Any tips for loosening them would be very much appreciated.
Thanks very much.
  • aero3113aero3113 Member Posts: 10,015 ✭✭✭✭✭
    Are you just using a wrench or ratchet? Try using an impact gun. You need the shock to loosen up the bolt. My impact gun is my favorite tool. It helped me tremendously with my FJ40 when I was pulling it apart. You have a good chance of snapping the bolt if you don’t use one.
  • TickledPinkTickledPink Member Posts: 130 ✭✭
    Thanks @aero3113 I shall invest on one.
    Harbor freight has some reasonable ones that work really well, compact also. I have their Bauer impact gun.
  • PickleRickPickleRick Member Posts: 4,400 ✭✭✭✭✭
    Find your favorite penetrating fluid and let it soak a few days.
    Start the boat up and let it get to normal running temp, or as close as possible.
    Try to pop them while warm.
    Good luck....always a slim chance of breaking the the head off the bolt
  • Rich_Rich_ Member Posts: 365 ✭✭✭
    Kano AeroKroil
    Amazon https://a.co/d/07bOSwC7 and now even at some auto parts stores
    Aerokroil is great stuff.
  • raybo3raybo3 Administrator Posts: 5,620 admin
    @aero3113 yeah its great stuff because your name is in it.......LOL
    Sadly I can't always get all the stuff you guys use as I'm on the Isle of Wight off the south coast of England.
    However, I have soaked them with penetrating oil and have bought an impact wrench so fingers crossed, the bolts will be nice to me. I'm going to work on them over the weekend.
    Thanks for all your help.
    In a pinch one can melt crayons to assist with the removal of rusty hardware
    Ok, in all my years of fixing things, this is new to me. Does the melted wax wick its way into the threads to lubricate them ?
    That is the theory, but Kroil works better
    It does.  Obviously there are better ways but it works in a pinch, especially if its in a recess where it won't run off
  • captkevincaptkevin Member Posts: 603 ✭✭✭
    Kroil is great stuff
    edited August 28
    The advantage of a wax as penetrating lube vs your usual hardware store or automotive section penetrating lube is how it acts when heated.  Most can lubes evaporate when heated, usually quickly.   Wax will continue to wick its way into the threads as the engine runs.
  • rasburyrasbury Member Posts: 9,001 ✭✭✭✭✭
    Make sure you have no gas fumes as you are melting wax! Just because they bolt heads have rust on them i don't always see a problem with the threads...
    I've managed to get 5 of the 8 undone so far. The others are not playing nice. I'm determined though.
