Fiesta Vee 242 Propeller
JCDes
Member Posts: 1 ✭
Hi everybody, just got a used 2001 Fiesta Vee. Which propeller would fit best my 242? I use it on saltwater, over 6 adults most of the time.Right now it has a 16x16P 3 blades. Hard to get it flat and straight with more than 2 adults.
2001 242 5.0L Bravo 3 ration 2.2
I almost always use the trim tabs even with 2 people, and when i'm up to 6 adults it's a struggle and need to move people around. The good thing is I can get a nice cruising speed of 40km\hr at about 36-3800RPM no problem on a light chop.
When it's on the rough side she struggles to stay a constant speed and stay on plane my hand never leaves the throttle.
Like all things in life it's a trade off I suppose: lower pitch would give better speed and on plane control, but less cruising speed efficiency when it's mild and going reasonable distances.
I'm happy with the set up I got, I have played with props on my ski boat in the past... the prop sizing calculations using factory and actual measured WOT speeds does work, so take a look there as well.
Cheers,
Rod
