What is this toggle switch for?
John41John41 Member Posts: 120 ✭✭
I have a 2004 Rinker 342. My boat is on land right now for the winter. When I hooked up power I was getting a reverse polarity light on my circuit breaker panel. In order to get that light off I had to put that toggle switch in the center. Does anyone know what that switch is for?
    Selects which power input is going to be shown on the meter. If the A/C line was unplugged - no volts. If it was plugged in and didn’t show reverse polarity and green then the main input line has an issue.
  • John41John41 Member Posts: 120 ✭✭
    Thank you. I believe it was set on main when I got the reverse polarity light. Now that the toggle switch is in the middle I don’t get any reading on the meter but I do have power to outlets and battery charger. I don’t know why I’m getting that reverse polarity light.
    Try different outlet or stanchion. If the same then possibly cable or earth.
    Are you using a regular extension cord and an adapter?  I had a similar situation when i used a cord from the marina and it was that the ground prong was missing and the plug was put in reversed
    When I first brought our boat home- I had the converter adapter for home circuit so could charge etc. My cord ran up to a bar plugged into the house outlet- had the same problem. It has to be plugged into the outlet with the cord. Everything was grounded with all its parts!
