Rusted intake
rasbury
Member Posts: 9,027 ✭✭✭✭✭
I mentioned on @aero3113 's thread on his engine project- here is mine!
I think it's not as bad as the 1st picture looks but I need to know how to pull the rotor and re assemble without screwing up the timing...I'm fresh water cooled so that is on the outside not rusting through.
I had thought water was getting there from the stern seating but it is not. The fire protection matt that is attached to the underside on the engine hatch has come lose in the back- apparently full of water..and is running onto the intake. The boat stays covered and the rusted area is not really wet. The table mount is the only place I can see where the water could be coming through. There is no sealant around the pedestal base...tips on pulling that please?
https://youtu.be/3UtdR642Wlg?is=TlEZxSMsPVW3ur7M
I also noticed on that video, that motor has the same rust in the spot I'm dealing with..
I don't have the ability/training to go inside the motor for sure.
I don't know why he had the motor down but obviously more of a repair to something else and perhaps the crank moved. I was really surprised to learn about the lack of timing adjustment yet relieved at the same time. Knowing it has sequential fuel injection is pretty impressive and I'm sure saves fuel- hard to imagine consumption could be worse. With all that simplicity and tech with the injectors, I'm surprised it does not have a fully electronic ignition.
Anyone with any motor interest, this is a great video on how the ignition system and fuel control works, thanks for posting.
Watching also re enforces as long as on the rotor it goes back in pointing the same way and I mark the rotor "tube" and the manifold it's not going to matter about TDC for what I'm doing...I need to figure out which was the rotor will "twist" going back in. I assume if I'm a tooth off it would be really obvious.
https://youtu.be/N1W5VuheoKs?is=7I0HnY73Z6sofpnC
