Fuel starved?
I have a 2003 rinker 270fv. I helped out a stranded boat by taking 10 adults plus myself about 2 miles to the nearest marina. I was not able to get on plane with all those people (nor did i expect to) so, i proceeded slowly to the marina. After dropping them off and getting underway, the engine began cut out after going above 3200 rpm. No alarms, no overheating. I limped back to the the dock at 3000rpm and 15mph. Does this sound like a fuel filter problem that may have been exacerbated by the heavy load. It looks like there is an inline filter near the gas tank and one closer to the engine. Any help would be appreciated.
If so, I'm willing to bet your boat will be fine by morning..
We call it the 'dumped load crawl'... I've heard all kinds of suggested reasons as to why it happens, but none solid enough to explain it.. the commonality, though, is after killing it long enough for it to completely leak down, its good to go in dang near every case.. go figure?
I personally think its either a load index being drastically changed as registered by the pcm cross referencing the manifold absolute pressure with the air intake temperature, and bouncing it off of throttle position and rpm and altering the adaptive table because of it, and throwing everything else it's learned out the window until there has been time elapsed and a couple key cycles, or, its hella simpler and its a simple vacuum issue and the same adaptive table referencing the rpm to the vacuum signal and drafting a new map in the adaptive tables.....
I bet if you put a scanner on the thing your short term fuel trim and your long term fuel trim don't reconcile.. I bet the stft is double digits positive where the engine was adding fuel, and it simply hasn't reconciled or tossed the wild data collected during your loaded run.. either of the above situations can, in theory, can cause the pcm fuel trims to trip out, but which is more likely, I don't know...
Oh, and don't laugh.. I've got buddies with theories much wilder than mine!!
At any rate, I bet its fine by morning... Hide and watch.. :-)
vacuum in gas tank, absolute fact with small outboard, but never saw a built in tank do it...
Anti siphon diaphragm or positive flow valve in regulator or filter/separator being exercised and stuck..
Eh... I don't know what causes it... I quit.. I need another beer.. I bet you're fine after the engine leaks down, though, and tosses the goofy trims the adaptive table stored by figuring them into ltft's, and in affect washing them.
The obscene stft's have contributed to your ltft, but its impact is minimal... If you want to start fresh on all adaptive tables because you think they've been 'tainted', start over by pulling power and waiting a couple minutes before reconnecting.
