Twin 5.0 mpi's, 1 with low temp?
Marcdohc
Member Posts: 58 ✭✭
So My 05 300 with 5.0 MPI Merc's seams to run fine but the starboard one stays cold and when the port side reads 180* the starboard side reads 75* to 100*. Any ideas whats wrong? Thanks for your imput, Marcdohc
Just a guess on my part. If the thermostat is wide open causing the engine to run way too cool, you might also notice the oil pressure is a bit high. Cold oil, higher pressure.
Tony
Salt Shaker 342
