Battery switch
Just got my 270 vee 2007 model, what battery (s) is being used when I flick the accessory switch up and leave the isolator in the off position?
  • CPSMARINECPSMARINE Member Posts: 24 ✭✭
    check the wiring diagram for you boat, or unhook each battery one at a time till the accessory looses power!
    Are you saying you have 12V when the battery switch is on the Off position?  You shouldn't, unless you are connected to shore power and the charger is by-passing the switch.
    I have helm power when my batter switch is off....not sure why either but the lights, engine cover will work....radio will not.
