342 bow rails - resealing
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
I'm on one of my off season projects: resealing the bow rail attachment points. A couple of the bolted locations I can manage to get to, but several require getting behind the vinyl wall covering. Anyone else done this? I hate to cut the stuff, but it would be an adventure to try and pull it down and I assume it would tear up the foam backing.
An old thread, yes, but I have a 2004 342, and the bow rails are starting to get a bit loose. Not sure if there's any water intrusion yet, but want to prevent it. It doesn't seem that there are bolts at the base of the rail, just large stainless steel screws.
I was thinking of unscrewing each base, one or two at a time, cleaning out the old sealant, applying fresh 4200, and re-inserting the same screws. No bolts, no ability to get to the back of them.
Do you guys have any thoughts/suggestions?
Thank you,
Ed
Elangone: I redid (3) mounts on my port side this off-season and will do the starboard side off season too.
The bow rail is through bolted, so you need access to the underside to deal with the washer/nut. There lies the fun...or not. On the port side I was able to get to the most aft from under the storage area under the cockpit seating. Moving forward from there, the next two you cannot get to without cutting a hole in the shower/bath enclosure, the next one moving forward you can get to but you have to take apart the top shelving section to get at it (behind/over the coffee maker) and cut into the liner to expose them - no biggie as no one can see it anyways. The next one moving forward you can get to by again cutting the liner..you have to feel around to locate the nuts before you cut (I need to get the vinyl repaired for this one). The last and final one at the bow..again I could not get access to the nuts. On top of this all, they sealed the nuts over with caulk and it is a pita to pry off to get to the nuts.
Most all my fasteners were bent from being tightened against a non flat surface and they were all cut off at the ends to shorten them too.
I used butyl tape to reseal the ones I could get to, way better than 4200 IMO for this.
Here is a great link:
http://www.pbase.com/mainecruising/rebedding_hardware&page=1
The starboard side all but the most forward mount location is doable via cutting the liner or from other locations (cockpit garbage can area and the subwoofer).
Good luck!
Thanks and oh boy, this sounds like it's going to really suck!
