Quads rings for Gen cool 111
frenchshipfrenchship Member Posts: 1,079 ✭✭✭
Does anybody knows where to get they quads rings for the Gen cool 111 the older models not the new ones. All my research did not shows any part no. Thanks
    Yes but lot smaller
    edited October 2013
    Take them to a Motion Ind, AIT, Grainger store. They can interchange easily.
    I will check with them. Thanks for the Infos Paul
  • Dream_InnDream_Inn Member, Moderator Posts: 7,944 mod
    Make sure you get something though for the correct application (fuel).  Actually, now that I say that, these are on the water side, right?  Ignore what I said.  Make sure you check those water fittings on it as well, I do know they corrode.  I ended up replacing both of my complete pumps/coolers this year.
    Nitrile is more than fine. Viton is nice but expensive and really meant for high temps. Silicone is also nice but very sensitive to cuts/nicks.
    I think that I was able to find a parts no:25-865363 for them not sure if they will fit but for .40 cents(U.S. : ) ) each it worth a try. If not I will go BD ways. Thanks for all the Infos. Paul
    P/N 25-865363 is the right part no. for the Quad ring for the older model of the Gen cool 111. Paul
