342 air intakes
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
Working on another pet peeve of mine this off season, doing something to stop the air intakes along the gunnel from being a gutter into the bilge. Anyone come up with a cure? I had my canvas made to snap over the openings, but it's not enough.
Thinking of making a plastic spacer to fit under the intake grill to raise it up .25" and seal the base with butyl tape or install an o-ring. The harder one is the more bow one at an angle, thinking of just an AL sheet metal piece at the upper corner to divert the water. Then of course seal the top cover piece.
Happy Friday!
So here's my start of a solution for the water draining in. Putting in AL spacers I had made under the intake grills. The one on the angled surface is a tapered spacer to allow fit under the top cover (not shown). These will screw to the boat and there are tapped holes for fastening the grill to the spacer. I'll bed both with butyl tape, I did seal the exposed wood in the hull thru holes too as that was getting wet also.
Still considering a custom duct opening, I think this will help a lot as my canvas covers the openings when snapped down too.
Maybe I'll go digging around to see if I have something laying around behind the shop. Good fix BD.
