Engine Impellers
Hey Guys,
How often do you change out your engine impellers? I was told they last longer if the boat stays in the water. Mine have 4 seasons on them. Should I change them this spring?
2005 342.
Thanks,
Hamdog
agree that 4 years is pushing it. a boat staying in/out of the water shouldn't make too much difference on how long it lasts. the water pump stays full of water whether the boat is in or out... unless it dries out from long periods of not being used.
2-3 years depending on hours. less if you've gotten into sand/dirty stuff with the drive... which can tear up the rubber...
The other, far more important tip is to pull your old impeller and take it with you to the parts counter to MAKE SURE it's exactly identical in height/diameter (see pic). As Al pointed out in my other thread, there was a recall on some of the Mercruiser OEM impellers and you might get one that'll be just a smidge(3/32") too short and won't prime(even the ones that were re-stocked as within spec). Of course I got one and took my pump out 3 times troubleshooting the mystery. To make it right Mercury sent me a brand new $430 pump assy if I'd simply return the defective impeller for my trouble. I considered it great customer service but I'd have rather just gotten the right part the first time so check CAREFULLY. The upside is that I can now change an impeller in minutes.
Good luck, Mike
Merc thought they had it figured out with a bulletin to all suppliers to check their stock and place a green dot on those that measured to spec or return their stock for replacement. Mine was OEM, sealed AND had a green dot but still clearly came up short. They were all over it when I called Merc directly who assigned a top guy to my case once they saw the above pic that was taken at the Merc dealer parts counter.
Thanks to Al for the heads up that solved my mystery and to Merc for rectifying my problem while also aggressively perusing a larger fix.
