a plug is a plug?
here's my dilemma... my 2005 350mpi uses the ac 41-932 plugs which around here are hard to come by and very expensive, I hear the ac 41-993 are the new version and I can get them almost anywhere. are they the same or which plugs would you run? here's the kicker... I e-mailed ACDelco.com and asked them, it's the world wide site and they said " not sure you'll have to contact the nearest dealer." what kind of answer is that? thanks, jim l.
don't be fooled by semi-precious or exotic metals, they are SOMETIMES better, and oftentimes NOT... it all depends on the heat range and the bowl design of the cylinder...
hotter plugs are fine for cooler running engines... cooler plugs are better for hotter running engines.. it's all about controlling ignition- you don't want the a/f load in the cylinder firing off of a red hot plug tip, or off of a hot valve- you don't want a 'slow ignition' either, which happens when a plug only ignites a portion of the a/f load and relies on a portion to ignite the rest... you want an even ignition at a precisely controlled moment...
Al has said in the past that these engines like iridium... personally, I like good ol' copper with a wider surface than the pin-point style of iridium.. either way, check with the OE and run what the engine was designed to run... I say again: check with the OE and run what the engine was designed to run... (Al's opinion I highly value... and it makes sense, as these engines operate at or just above 165*f, which means you can more than get by with running an iridium plug with a fine point tip, as the cylinder is likely not hot enough to pre-detonate an a/f load all by itself).
off the cuff, however... if you want to improve power, economy, and control: use an iridium plug gapped around .060 and replace your coil with one that produces 45K+ volts... also, index the plugs, which is an old rodder trick that has been validated many many times: make sure the gap of the plug points toward the open portion of the heads bowl- it will ignite more readily and cool more rapidly.
I get my plugs from Summit Racing Online. decent price, no sales tax and only takes a few days
and delivered to you door. They do have the AC 41-993.
Len
Len & Robyn 342 FV Freebird
The dudes finger is almost atop the plug boss.. imagine the design of a plug electrode-to-shank.. indexing the plug to where the open gap is pointing toward the open part of the bowl (bowl being top of combustion chamber), and imagine how much easier and certain ignition is when indexed that way.. that is a simple thing that increases power and economy.
I'm looking at buying two 30kw generators fired by Detroit diesels at an online military auction, for (dig this) <$100 each.. I'll then hire a Marine who works on them for a living to go through them and repair/service them.. afterwards, I'll implement automatic transfer switches to them both, put one on a skid with a tank, and sell it for enough to cover the the cost of outfitting them, and use the other for home back up power..
In that application, diesels can't be beat.. as far as smaller and easier powerplants, I'll take a gasser..
These don't have axles.. there are others that do, but are generally <20kW systems.. keep your consumption low during a power outage and you can get by with the lighter ones..
I live between cherry point and camp Lejeune, about twenty minutes on either side of me.. driving over and sweet talking a marine on a skid steer to load it is easy for me, not so Mich for folks out of the area.. if you're in the market, though, it would be much cheaper to swoop down from Maryland and get one as opposed to buying local, no? .. another key: I have a slew of local marines who work on these things for a living and have access to parts, that I can hire on the side for a few cases of beer.. :-)
