Building the 4.3
markgrmc
Posts: 9 ✭
Hello to all. Just purchased my first Rinker. It is a 1990 V180. It is in excellent shape except the previous owner forgot to winterize. So I have purchase a new block and heads and am in the process of having everything machined and cleaned for the rebuild. My question, are there any upgrades I should look at doing while I have the motor down, such as flat top pistons, a different cam and so forth and if so what would you suggest. I have already purchased an Eldelbrock marine 600 cfm carburetor and a hotter coil for it. Any help or suggestions would be greatly appreciated.
Thanks
Mark
Thanks
Mark
as far as cam shafts go, which is the single best place to attack a build on dry ground, your choices are going to be slim.. you must have a marine cam, otherwise, you take a huge chance to pull water into the cylinders during the momentary 'equalized pressure' at exhaust/intake valve overlap.. that will end an engine pretty quickly..
another thing, is you should consider the range- you need a steady pull through the RPM range for a boat, starting around 1400rpm and all the way through 4800rpm.. whereas a car can be built for top end, low end, or mid range specific..
I've been toying with the idea of playing with my valve train geometry, and working around the marine cam... the lift can be increased with higher ratio rockers, but you can only go so high with those, otherwise you'll start rubbing the push rods against the head casings... My notion is a lil' different, which is to increase the ratio (and lift) of the intake valve, but leaving the exhaust alone- thereby increasing it's velocity.. I'm thinking there are a few ponies hidden in that lil' action..
You're so early in a build that if I were you, I would consider dumping the carb and moving toward a throttle body instead, and full MPI EFI.. I took me a long time to accept the merits of EFI, but there is no way you can build an engine intended for long life as hot with a carb as you can EFI... the MPI EFI system is controlled by a computer, which not only trims fuel as needed but also controls spark advance/retard, which again allows an engine to last a lot longer as well as produce more power and fuel economy.. because spark is controlled so much better, 'floating' (advancing and retarding), you can get more use of those flat top pistons and increasing the compression ratio- which, will produce more power in the end, and actually increase durability and life.
or.....
Man, you can slip a small block in there with very little added weight or space, and nudge right up to the rated torque your outdrive can handle, and with wicked ease- which means even more durability.
While I am asking questions what prop would you recommend for my boat? It is a 1990 V180 with the 4.3 we have been discussing.
Do you really think that an EFI system will make that much difference over the 4 barrel Eleldelbrock carburetor. I guess I could look for a used set up.
Thanks again
Blocks can be interchanged.. cams can't be.. you could run a marine cam on land but not a land cam on the water..
Do yourself a favor and google port matching heads to both intake and exhaust manifolds/gaskets.. there are 25-30 ponies hiding out in that simple procedure you can do yourself with a grinder and a steady hand.
Heat of spark doesn't matter if you advance timing too much, compression doesn't matter if you don't control spark.. higher octane makes gas more inert, not more explosive.. lower octane is more unstable, hence, more likely to predetonate under compression or cylinder heat alone, especially in high compression engines.. higher rand allows the air:fuel not to go boom until spark hits it.. you'll be fine up to about 11:1 so long as you don't advance spark too radically.
Edited to add: mechanical compression ratio isn't as important dynamic compression ratio. Dynamic takes into account valve events.. a mechanical compression ratio of say 11:1 is likely less than 10:1 dynamically.. you can run 87 on 10:1 all day long so long as you don't advance timing too much, or, run 91-93 rand and advance to and north of 40* advanced.. the more compression and spark advance, the more complete and powerful the burn..
The overlap and opportunity for ingesting water is real, but not as big a threat as what it's made out to be on these high riser type engines several pipe feet from the exhaust tip... What is a huge deal is getting a cam with the right power band range. That s10's grind will struggle with its tq/hp range. look sir something like a sausage grind, made for low to mod range tq.
