engine hatch
rasbury
Member Posts: 8,242 ✭✭✭✭✭
As soon as I'm done with my brakes, it's down the hatch to fix one sea valve and check/service if possible the others. So far all I've done with the engine compartment is impress my friends making it go up and down. Two questions with regard to it, while it does give you fair access, can it be disconnected so you can open it all the way? I would like the area as open as possible. Also, if the battery goes dead and there is not access to shore power, how the heck to you get it open?? I assume the motor will fail at some point so even beyond a batter problem, how do you open it manually? I tried a search and thought I saw a previous post before but could not find it.
If the lift ram fails you'd need to remove the table base and reach in to pull the pin. Assuming you had the pull ring turned toward the access......
I usually pull the hatch ram pin and prop open the lid when I need more room. My hitech prop is just a broom handle cut to the Ideal length.
Mike
Your Mercruiser fuel pump is on the frt starboard side of the engine near the raw water pump. There isn't a pump in the fuel tank.
The cig lighter to jumpstart pack patch cord is insightful for raising the hatch but you're right about those spare studs in the aft batt switch hatch. Theyre capable of handling a much heavier load like possibly jumping the engine/genset in an emergency.
The last time I had a lug spin I went to Sears and paid about $6 for a nut splitter and simply split the lug nut off of the lug. That allowed the wheel to come off. As the lug was already spun it came out with a hammer tap. Bought some very slightly oversized lugs and tapped one back in and was in business.
Dave
Moon Township, PA - boating in the Ohio River
Congrats on doing well at the ramp. That's no simple feat with a boat that size and your confidence will build with each launch as the right steps become 2nd nature and the mistakes and wasted steps become fewer.. Hope you got those brakes and lugs fixed too. Otherwise I'll just keep my distance if I see you on the road.
Mike
