Anode Replacement?
rinker312rinker312 Member Posts: 255 ✭✭
All, I spend all my time in fresh water and use magnesium anodes.  Last few years I have replaced them every year prior to going back in the water.  The old anodes are pitted, but are for the most part the same size they were when I put them on.  do you think I need to replace them every year like I have been or can I maybe get two years out of them?
Your thoughts are appreciated.
Thanks.
    edited March 2014
    From the archives:
    Choosing anodes LINK
    I don't bother unless they're less than about 60% of their original size. That said, it's not a bad idea to annually clean and re-seat them where they contact the boat. If a layer of debris/dust forms under them it can render them ineffective due to the lack of a good contact. A cracked or damaged anode needs to go.
    Good luck, Mike
    I have spent some time in your area and have relatives scattered around Jasper/Decatur/Birmingham/Huntsville/S Pittsburg tenn and have also spent some time out on the Tennessee river. It's a beautiful area. Where do you spend your time boating? Noticed your pictured on a trailer. That's a lotta boat on wheels.
    Post edited by TikiHut2 on
  • LaReaLaRea Member, Moderator Posts: 7,837 mod
    I'd recommend replacing them every year with magnesium.  Even if they looked okay last fall, you never know when conditions in your slip might change mid-season (e.g. a current leak).  If you start the season with partially depleted anodes, you'd run out of protection that much sooner.  New anodes are cheap insurance.
  • Cableguy GregCableguy Greg Member Posts: 5,039 ✭✭✭✭✭
    I replace my magnesium anodes every year. I feel that it is cheap insurance.
  • Robyw1Robyw1 Member Posts: 56 ✭✭
    If your boat spends all of its time in the water I would change them every year. If it is a trailer boat I would think you could skip a year.
    I get usually a couple of years out of mine no problem. The only time I didn't was due to a Searay plrked next to me that must of had a leaky ground which wore out my anodes after one season.
    I am in the water from mid April to May through October then I pull her home so that I can work on her in the driveway trailer was the best thing I ever bought. I think I will try to reuse them this year. I often go under and check them out so if they seem to be fading fast I can always change them mid season. Tiki, I am on lake wheeler near rogersville Alabama. It is nice there and even on holidays it is like having the whole lake to yourself not a lot of traffic. Thanks to you all for your thoughts.
    I would replace. There is a company, boatzincs dot com that sells them at a decent price. I get them from them every year. For 60 to 90 bucks a year, it is cheaper than a new drive...
