gen set strainer
rasbury
Member Posts: 8,986 ✭✭✭✭✭
as previous mention, my gen stopped and shut down on my maiden voyage...working on getting the manual....working on my brakes still and was looking around the engine compartment wondering about the gen and for grins hit the start and it started right up. I pulled the service panel and the only thing I see to check for fluid is the engine oil which is full. I wonder if something is stuck in the strainer? I see it but not sure how it comes apart. Also, previous discussion, no one seems to have a filter on their genneys but sure looks like there is one on this one.....so, I might be clogged and over heating or clogged and not getting enough fuel but it starts right up...how do I open the strainer? Have a servie manual ordered....
There are two long screws at the back of the cover, one at the front by the controller, plus two screws at the top of the side panel near the carb (opposite end of the manual start switch box). it is a bit tricky getting them back in, just warning you.
To get to the reservoir both panels need to come off (and to get to the backside spark plug). So to summarize: (3) screws on top, two on the side.
If you just take out the one screw from the top near the controller/service panel you can tilt the whole thing backwards and get to the pressure cap on the heat exchanger, but that's about it. You may as well learn how to take it apart
You have a few things you should check anually besides the impeller:
* Anode - it is in the heat exchanger
* clean spark arrestor
* Check coolant level
I can tell you changing the antifreeze is a real PITA and I'd avoid opening the coolant system if you can avoid it. You will get air trapped into the system and cause overheat shut downs, it can be avoided as I managed on mine last summer, so more an FYI.
Plugs should be NGK BPR 4ES (long nose)
I had them quote me the anode along with the impeller kit and plugs so will get that ordered...I would think the coolant would be do for change and a real concern is the drain pan has a lot of rust- I need to get that under control and slwed down as best I can...thanks for the info. I'm starting with service on the motor while getting this other stuff ordered.......how often should that coolant be changed?
The raw water pump is at the far end of the genset (opposite the carb). The little service panel you see gets you to the fuel filter installed at the fuel pump inlet. Personally, I removed mine and left the in-line filter mounted on the firewall, the one at the pump is extremely difficult to get to on my 342. There is no water seperator (or at least on mine).
Not sure what 'reservoir' you are looking for? The fresh water flows from the thru hull, thru the strainer, to the raw water pump, then the water mixes with the exhaust and finally purged out with the exhaust throught the muffler.
Proceed with all due care and follow the tips that these guys who've learned from pain/suffering on what to do and not do. If it runs fine don't break it and run the crap out of it. If it's problematic, focus on the parts that are causing issues and don't break something new while attempting/avoiding fixing another issue (I excel at this).
Good luck. Mike
@Dream: you completed the details
I agree with Tiki, if it is not a problem (coolant/thermostat or leaks): don't mess with it. I can speak with experience along with several others on here it is a pain and a mess to change the coolant and bleed the air successfully. That assumes you can get to everything decently, which is usually not the case.
8-}
yes, there is a fine line there between normal maintenance and getting into a heep of trouble which I also excel in. I just hate the idea of breaking down when if I'd just.......I 'll stick with basics for now, I do need to check the gen coolant level if only to rule that out as a problem.
Good details BD! Ras, it sounds like you'll be using that genny in no-time! Make sure you carry spare plugs and impeller. It will save the day (or weekend).
RY is correct, you can run the genny at any speed, but not sure why you would typically need to very often.
Hey, Great progress on the genset.
Replace the whole water pump.End of that story.
The drive oil is easy. drain n fill drive. Drain, rinse, refill tank. Check the Merc service sheet for details.
Don't handle the bulb on your spotlight with your bare hands. Oil from your fingers will often compromise the life of a high intensity bulb.
Brakes..... not a good idea to keep tempting fate on that one. If an insurance claim came up and they knew you were aware that the brakes didn't work it most definitely wouldn't go in your favor. But it sounds like your a lucky guy...
Have a great time tweaking the sea sled. Mike
