Unsealed drain holes in swim platform
LaRea
Member, Moderator Posts: 8,078 mod
Here's something to check on your older Rinker: see if the swim platform has drain holes that were not sealed.
When Rinker built my 342 in 2003, they drilled three drain holes in the swim platform. They did not seal these holes at all, or put in any sort of fitting. They just drilled 3/4" holes right through the fiberglass deck. Over time, the core has apparently rotted out from moisture intrusion. Now, after 11 seasons, there is a noticeable amount of flex when I step on the swim platform. There's enough flex that I'm getting some cracks/crazing in the gelcoat. I had a surveyor do a tap-test, and he says the entire swim platform is saturated with water.
Does anybody else have this problem? I know some swim platforms do not have drain holes.
