BOW THRUSTER
EDWINCEDWINC Member Posts: 39 ✭✭
on my 310 Rinker i have a bow thruster and all of the sudden it stopped working? does anyone know where the barker is? what stopped working is the joy stick it won't turn on.  i think its a barker switch.  or a fuse.
Sincerely Edwin C
  • LaReaLaRea Member, Moderator Posts: 7,920 mod
    Volvo Penta?
    Check for a disconnected wire on the backside of the joystick.  You'll probably have to take off one of the switch panels and reach around to the back of the joystick.
    If there are other wires lying on top of the joystick cable, it can put enough tension on the cable to pull a plug loose.  Try to pull the joystick cable to get some slack so it won't happen again.
    Let us know what you find!
  • EDWINCEDWINC Member Posts: 39 ✭✭
    checked the battery and its fine, check the big fuse and its fine, took out the joy stick and it seems to be ok.  but i still can't find the fuse that goes to the joystick..  any other ideas.
    Sincerely Edwin C
