Question on Engine Hours
DanD2
Member Posts: 848 ✭✭✭
Need some feedback from you folks.....looking at an 2005 342. Boat is in overall excellent shape but engine hrs are at 650. I'm having dealer do a compression check. If things look ok, should I be concerned with the 650hrs?
Thanx for the response LaRea,
Generator has 160hrs, absolutely no evidence of leaks. Swim platform feels very solid and it has always been in freshwater maintained by the marina. This is a 5.7 Volvo Penta DP.
I'm out to lunch on gel coats and fiberglass work.. I hope it works out for you, though.. I DO know that I sold a set of jetskiis a couple years back that were blistered, and know the guy I sold them to. After a local glass smith got ahold of them, they looked band spanking new..
Mike, appreciate your comments, dealer plans at their cost to do this. They have a pretty defined process on how to deal with this and I trust them but will probably take your advise and have someone look at it before they reapply anything!!
If everything looks ok, should I have them gel coat or bottom paint? Boat will be kept in freshwater.
Tony has an excellent point regarding those drives. He (and many others) had a very painful $$ experience. Do a search on Volvo drive issues to be sure you aren't buying the problematic version.
Try not to get emotionally attached and keep doing your research. Good luck, Mike
Surveyor checked the hull out and everything looks good. He popped a few of the blisters and nothing came out. A bit of moisture in a couple of spots on the transom but was very confident the steps the marina was taking would alleviate any issues down the road. They started sanding the waterline today....will make sure everything is dry before the barrier coat.
Here's a pic of the port side cut and buffed.
