Raymarine c80 problem - fuzzy
It seems that some gremlins have found there way into my c80. It will fire up and then I'll start to get lines through the screen or it will go to complete fuzz. Sometimes it will go to fuzz right upon startup. All connections seem fine and secure. I have new batteries and I'm showing 13 volts on the gauges so I think I'm good there to. Any ideas or has anyone else had a similar issue?
Very cold temps can freeze the screens and wreck them. Check your manual and see what it says about freezing temps. I know people near me take that stuff off in the winter just for that reason, usually below 0F the problems start with the flat screens, unless specifically made for it.
Otherwise, maybe an update to the operating system is in order.
you might have the same problem that the C70 sometimes has at startup--has to do with the screen making contact with the sensors below it. The quick and dirty fix is to use your thumbs and forefingers to press firmly on the screen. Use a napkin to prevent leaving fingerprints. Hope that helps--
