battery switch operation
rasbury
Member Posts: 8,990 ✭✭✭✭✭
Well, the wife is complaining about all the things I am running across, I'm just happy it's not on the water (so far) running into problems....confused a bit on my battery switch and have searched the forums and on line and really could not explain what I ran across. I think I'm having issue with one of the two new batteries- goes from don't want to start on battery 1, but the battery seems to "recover" and start later. I ran the boat all day (without really using power for anything else) So, I was going to pull that battery and have it tested, maybe it has a bad cell or something. Anyway, I wanted to make sure that the battery I pulled was number one. I can see the wires go up to the switch but can't really tell if they cross or not. So, I pulled the hot wire off battery one and put the key into the ignition and to my surprise, it turned on. So, I put that wire back on and pulled the wire off the other battery, and, to my surprise again, the ignition still turned on. The battery switch was left on Bat. 1 position. The switch was not on the both position. What am I missing here? I went ahead and pulled both batteries to have both of them load tested anyway but that was real confusing...do I have a problem with my switch? When battery number one would not start, I switched to #2 and it started fine. I also checked the alternator out put and I have 13.8V on one and 14 on the other so it looks like I'm charging ok...switch sure has me puzzled.
Also did you do this while the charger was on with shore power connected?
So, I'm wondering whether the shore power wasn't actually turning over the starter. It could very well be that the 110V supply was providing the energy via the charger, so it didn't matter that the battery was disconnected.
Try doing that test with shore power off.
