Mercruiser MAG 350 Problems
MarkB
Member Posts: 4,009 ✭✭✭✭✭
Well, I've posted this in the Rinker Boat Owners Forum - but that site is down now.
My brand new 350 MAG started consuming oil after 30 hours. Problem has been getting worse - it now consumes 350 mL every 2 to 3 hours of operation at cruise speeds (about 1/3rd a quart). The boat was taken out of the water for winterization and is at the dealer now to fix this. We did compression tests which showed 40% leakage through several cylinders.
Anyhow, we've been after Mercruiser for about 3 weeks now to tell us what to do. When we first called several months ago they said they would sort me out, now they have not responded in 3 weeks! I'm getting a bit tired of it. Do the warranties mean nothing any longer?? A customer shouldn't have to go through what I'm going through. I did everything right on my side. Being an engineer I strictly followed the break in procedure. Now, it seems I have to fight to get any attention.
It's a bit dissapointing to be quite honest.
I'll keep you posted.
Glad to see some people from the RBO on here. I can't help with you question since I have a 342.
I have also seen mike342 on here and Babyboomer joined back in 2010. I still think this forum is better
than facebook. What do you think?
Len
Len & Robyn 342 FV Freebird
If that doesn't work (they will do a leak down test after that), then they will give me a new engine.
To be honest I would prefer a quick fix as taking out the engine and replacing it will be a nerve racking excercise!
Glad to hear that Mercrusier has finally got back to you. I think if it were me I would want a new engine
or a extended warrente on the engine if they don't replace it. My boat is a 2002 and and have never had
to deal with Mercrusier. Just a FYI I have never had to add oil in between oil changes (50 hours or 1 year).
So if I were in your position I would want a new engine because there is something wrong with yours.
Hold your ground and get a new engine and hopefully next year will be a great year on the water.
Len
on this forum. It not that hard to figure out. I miss RBO but this site is here and can be useful. Just my opinon.
Len
Mikes 342 I hope this helps.
Hello all. Well to close this issue out, they found cylinder 3 was leaking oil. I got a brand new engine which was installed this week. I am very happy. Now I need to do the 20 h breakin again.
The rinker dealer did it, they are mercruiser certified. So I have coverage (in terms of workmanship) on both sides of the equation.
I used the opportunity to take out the Faria RPM gauge and replace it with a mercruiser smart gauge so I will have a lot more indication now. It even has troll control which may help my fishing.
Oh and one more thing ... the look/functionality of this site rocks totally now, much better than before.
