Replacing Plastic Tensioner with Metal
picturethis
Posts: 103 ✭✭
The bearing in the plastic tensioner pulley is going bad on my 2000 7.4 MPI . I was going to replace it with a metal pulley with a larger sized bearing (same size pulley)
Is there any reason i shouldn't do this?
I am a new boater with my first boat, thats why some of my questions seem dumb
A metal pulley will rust and then you will get squeaks from the belt too. Eeek. Eeek. Eeek.
I had this pulley break this weekend it broke in half and I am also trying to figure out what to replace it with and if I should replace the full pump. I have learned that on the 5.7 merc bravo 3 that there is supposedly a kit with metal pulley and new belt. Service rep says the old belt won't fit with new pulley. The new full pump has a metal pulley however and no one has said a new belt will be needed. I would like to see more discussion on why the plastic was used. It seems like you all are saying it is better for noise. Thoughts around these issues? Thanks guys
